Drivers window tab the bolts to the regulator`
Hey all
The rear tab that is fastened to the front drives window tray (Metal that holds the window) then bolst to the regulator has separated from the tray.
Has anyone just cleaned the area up and spot welded the tab back on to the tray?
I know this is close to the glass so a chance of it breaking is present.
One problem you face is normally if the tab is rusted enough to break away you won't have enough metal to weld to the channel.
SUX, but I believe the lift channel on the DII is not sold separately like on the DI ( # ALR8022 ). I hope I'm wrong.
Either way if you weld it and the channel tab doesn't hold or the glass breaks you are off to ebay for a replacement glass w/ channel for under $100.00 ( SEARCH: CUB102710 )
kdscott100 (02-21-2024)
I get what you want to do is reattach the tab on the window lift channel.
It is not sold separately. The tab looked in pretty good shape but I had yet to look at the "tray" part.
