Driveshaft - 03 Discovery II
Old Jul 21, 2017 | 04:34 PM
Rdr8887's Avatar
Originally Posted by Alex_M
This isn't true for a D2 because of the proximity to the catalytic converters which give off a ton of heat. I would never use a junk yard unit except in a pinch.
D2 shafts have to be retrofitted with greasable u-joints (aftermarket already have them) and they have to be regreased at every oil change.
An OEM unit would likely be fine. And a quick check aftermarked confirmed my thoughts on price. This is for material only.
Rdr8887's Avatar
Originally Posted by lively
The dealer said my U-joints are failing which based upon what I have read is a common theme.
U Joints are designed to be replaceable. They are about $30 a piece for good ones.
Old Jul 21, 2017 | 05:11 PM
lively's Avatar
I've learned that. No since in me getting one off a Land Rover that has been sitting when the failure rate is high.
Old Jul 21, 2017 | 05:13 PM
lively's Avatar
That's interesting. Would failing U-Joints cause it to drop as I've been told?
Old Jul 21, 2017 | 09:11 PM
No Doubt's Avatar
Talking
Of course! Those 2 bolts on the U-Joint are what is holding the driveshaft on.
Easy fix.
Old Jul 21, 2017 | 09:40 PM
Best4x4's Avatar
You can get a high quality front drive shaft that is MUCH better than the OEM unit with 4 zerk fittings (3 on U-Joints & 1 on the slip yoke) for 115.00 if you look around with free shipping. I bought my friend a unit off of Ebay for 130.00 with free shipping & that to me is better than rebuilding your old OEM unit.
Old Jul 21, 2017 | 09:50 PM
mln01's Avatar
Thank you. The dealer quote is 1,412.
Dear. God.
An immeasurable amount of space on this forum and others has been taken up discussing driveshafts.
First. STOP DRIVING THE TRUCK UNTIL YOU REPLACE THE FRONT DRIVESHAFT. Ignoring this advice could easily mean you need to replace the transmission because the driveshaft lets go and beats a hole in the side of the transmission,
Second, never, ever get a replacement driveshaft from a Land Rover dealer. They sell only the POS original style that does not have greaseable U-joints. That is what contributes to them failing in the first place.
Third. For as much trouble as I have had with them call or write to lucky8llc.com. They are selling a fully greaseblel driveshaft at a price that makes it not worth it to try to rebuild the one you have.
Fourth. Once you replace the driveshaft be sure to grease it every time you do an oil change.
Fifth. Replacing the driveshaft is not a difficult task if you have basic hand tools. The price quoted by the dealer helps ensure their Caribbean retirement.
Good luck, and don't be afraid.
Old Jul 22, 2017 | 04:46 AM
lively's Avatar
Originally Posted by mln01
Dear. God.
I appreciate the response. I checked out Lucky8 but they had just closed by the time I called. I have typically bought parts from RockAuto but being completely unfamiliar with the LR driveshaft, thought I'd look elsewhere. The dealer provided me that quote at the same time they fixed my intake leaking on my 02 sensors. 2 mechanics looked at that problem and referred me to the dealer. I couldn't fix that myself but I damn sure can learn how to do the driveshaft.
Old Jul 22, 2017 | 04:48 AM
OffroadFrance's Avatar
For normal highway use they last about 100K miles but offroading 'kills' them quicker. If the driveshaft breaks you MAY end up with expensive damage to the autobox.
Old Jul 22, 2017 | 04:53 AM
Excellent comment ............... so true
