Driveshaft Question
RE: Driveshaft Question
I still have about 2 years left on my LR certified warranty. Am I better off paying out of pocket to get this issue resolved, or is it better to see what happens in the next 2 yrs. I assume that if the driveshaft fails and smashes my tranny, that this would be covered under the LR warranty?
He is talking about the double cardon failing, the dealer wont due squat right now, except sell you a new driveshaft.
Personally I wouldnt take the chance that it will be covered under warrenty, that is a $7,000 gamble.
Any drive line shop can rebuild the front driveshaft using greasable u-joints. That is what you need done.
I have zero faith in extended warrenties and if you take the gamble and you are wrong...
I had mine done on my 2004 disco at 97000 miles. I do most of my own work but have found that driveshaft work can be done reasonably at a local drive shaft shop. I inspected mine when it was removed and it was not worn out. I would recomend replacement or rebuild due to other input from members of the forum. I had all u joints replaced with greasable joints and the centering ball kit installed for $150.00 in Winston Salem NC. Only took about 2 hours for them to complete.
robert.juric
11-03-2022 06:08 PM
