Driveshaft replacement without jacking?
Old Apr 2, 2019 | 04:01 PM
Best4x4's Avatar
Metric has never worked for me, I’ve just busted knuckles or rounded the nuts. A 9/16 open end works great (thinner head on tje closed side the better). I leave it on the ground in N and just push it forward or backwards a bit on a flat surface.
Old Apr 2, 2019 | 04:08 PM
Motorhead1's Avatar
Mine has standard threads, when I replaced the marred up nylock nuts (from metric sockets/wrenches), I was surprised to find out that they were an American thread nut, I don't recall the size. I also jack up the front wheel, auto transmission in neutral with parking brake set.
Old Apr 2, 2019 | 04:09 PM
OverRover's Avatar
Same here, from the factory the driveshaft bolt ( 509045 ) and nut ( NZ606041L ) have a 9/16" Hex Head with 3/8" UNF threads.
Old Apr 2, 2019 | 04:45 PM
mollusc's Avatar
off topic here, but i think this is the first time i've ever seen non-metric referred to as "american" thread. most of the time people seem to call it the english system. i grew up calling it imperial.
Old Apr 2, 2019 | 06:15 PM
Motorhead1's Avatar
I've called it "Standard" also? Maybe I'm just backwoods sometimes.... I think most will agree the metric system is better. The early 90's?? Maybe even the late 80's, here in the states was a tuff time wrenching on American cars, half the nuts/bolts are metric, while the others are whatever you want to call them....lol
Old Apr 3, 2019 | 12:12 PM
ahab's Avatar
I've always referred to them as SAE which I assumed has something to do with Standard but apparently it references the Society of Automotive Engineers, who set out to standardize hardware sizes a long time ago. 9/16" definitely fits better than a 14mm on the DS nuts, but it also depends on the quality of the wrench. The variance is about a hundredth of an inch so a cheapo 14 may fit better, but 9/16" is the way to go. And yes, just to confirm with all the others I changed mine without jacking the truck up.
Old Apr 3, 2019 | 01:09 PM
Motorhead1's Avatar
Yes, SAE, I had a brain fart yesterday, and the day before.....
Old Apr 3, 2019 | 04:50 PM
DavidOHendo's Avatar
Banned
How tight should you do it ?
I bought a replacement bolt kit from BritPart because my bolts are from 2000. I wanna change em out but I don't have a gun.
Old Apr 3, 2019 | 07:12 PM
ahab's Avatar
Here's the spec from the RAVE. 35 ft/lbs.
Old Apr 4, 2019 | 01:23 AM
Banned
whas that by hand
