Driveshaft view and advice?
Old Sep 22, 2013 | 06:39 AM
cimomd's Avatar
Originally Posted by gbob
Yes, five grease fittings and not four.
See photo below to find the 5th fitting.
Thanks for the correction GBob, in any event I hope this is a good prophylactic measure I am takinig in replacing the shaft with a new one. The mechanic reported to me that the front drive shaft looked remarkably clean and intact which makes me question whether it is a replacement itself? I'm not sure, but I can't wait to get my vehicle back, been in the shop for 2 weeks getting the necessary maintenance it deserves and one more won't kill me.
If anyone has any experience with the BPUtah shafts let me know, I am sure they provide a good product based on my past experience with them but have not had any feedback on their shafts.
Old Sep 22, 2013 | 11:50 AM
gbob's Avatar
Hey Cimomd:
I installed the front prop shaft myself a couple of weeks ago and so far so good. My prop shaft is from BP of Utah. The unit came all greased up, but have your mechanic confirm and grease up all 5 points just be prudent. One thing to point out to your mechanic: I think 7 or 8 nuts to remove, but not all the bolts; just four. Nearly impossible to remove the 3 or 4 bolts located at the rear of the truck. Just loosen and remove those nuts and leave the bolts intact. You could remove and replace all four nuts and bolts on the front (front, meaning under engine), but I recycled mine. FYI.
gbob
Old Sep 24, 2013 | 12:32 AM
cimomd's Avatar
Hey Cimomd:
gbob
So you are saying just remove the nuts and any bolts that don't freely come off just leave on is that correct? I will let them know thank you.
Old Sep 24, 2013 | 06:23 AM
drowssap's Avatar
yes there are only 4 nuts and bolts. the nut should be replaced, they are "nylocks" meant for a single use only
Old Sep 24, 2013 | 07:52 AM
gbob's Avatar
Drowssap is spot on. However, I reused my nuts, but then again, I'm nuts anyhow.
Old Sep 24, 2013 | 09:37 AM
bballjames's Avatar
I've got one. Had it on for almost a year. So far so good. I haven't had any vibration issues. It's a well built shaft.
Old Sep 25, 2013 | 07:05 AM
jfall's Avatar
You could put on blue not red thread locker to the nylock nuts and reuse them.
But then you may not get the nuts off a third time.
That shaft the Good Dr. showed in his photo looks just like my shaft.
I have a 2001 and I now believe the Good Dr's shaft is the original.
I too look to have the original shaft on my truck still at 105K miles.
Old Sep 26, 2013 | 02:33 AM
cimomd's Avatar
I guess I'd rather be safe than sorry and replacing it with a new serviceable shaft is rational. I shall post updates once I get the vehicle back in a week .....
Old Oct 13, 2013 | 01:17 PM
Pipes's Avatar
Any update?
I replaced my front driveshaft with a Tom Woods today. It is not complicated but it turns out the nuts/bolts are 9/16, not 14 or 15 mm. I replaced all the nuts with new grade 8 nylock nuts and reused the bolts.
Old Oct 14, 2013 | 01:43 PM
cimomd's Avatar
Originally Posted by Pipes
Any update?
Pipes, yes, Ive had the Disco back for 3 weeks now after major service and new BP Utah shaft install. All bolts secure and it was an easy replacement. The vehicle is driving like night and day, smooth. I think part of it also are the maintenance tasks found in the major service 60k/100k items, I had BOTH done plus the shaft install. Just recieved a Terrafirma front winch bumper that is going on this week also. Hope this helps.
