Drivetrain Clunk
Old Feb 9, 2006 | 11:27 PM
bmartin2's Avatar
4th Gear
Default Drivetrain Clunk
I have a 2000 D2 and really love the truck. One thing I notice which bothers me is I hear a clunk in the drivetrain if I'm traveling 45-50 MPH and I let off the accelerator and then back on it. If I gently press the accelerator than no problem but if I quickly hit the accelerator I get the clunk.
Is this common? Suggestions?
Old Feb 10, 2006 | 03:33 AM
mikemeyer0's Avatar
Default RE: Drivetrain Clunk
check u-joints, u-joint bolts, there will be a bit of a clunk during these conditions but not real bad. get a wrench and try to tighten all the u-joint bolts, also a siezed u-joint can be the problem, but a simple grab of the drive line and trying to twist it won't tell you anything, actually get under and inspect.
Old Feb 10, 2006 | 09:20 PM
bmartin2's Avatar
4th Gear
I just replaced the front drive shaft about 3 months ago. Rover dealer did not mention any other problems
Old Feb 11, 2006 | 10:47 AM
Landzu's Avatar
From what I have found it is most likely the ware on the out put shaft of
the transfer case most DI's have that and some DII's.
You may here a clunk when you go back up also.
It will last for years and years like that with no problems, if that is
indeed the problem.
Old Feb 11, 2006 | 10:27 PM
Bait's Avatar
You do not specify milage. It is normal to have significant clunking in the drivetrain. One warning. The front driveshaft on dII's has a double cardon type joint that is not grease-able. This is prone to failure @ approx 100K. It can also take out your trans case.
Old Feb 12, 2006 | 01:25 PM
Landzu's Avatar
I checked and transfer cases that are LT230Q the Q is the updated one
and has the clunk fixed.
Old Feb 12, 2006 | 11:43 PM
Bait's Avatar
The "Q" refers to the gear cut, not clunking.
Old Feb 18, 2006 | 02:49 AM
SSped's Avatar
The only Changed the gear cut in 2002 or 2003. The clunk is more than likely normal. 1998 and older Disco's have a Input shaft that can be replace and can repair some clunking. D2's do not. check the ujoints in the front prop shaft. other than that you are hearing normal drive line lash. I have seen the ujoints wear out around 40 to 80,000 miles. The a/c drain tube drops water directly onto the front prop shaft causing the joints to rust and fail. This is usually noticeable with a Squeeking rotational noise and a vibration durring acceleration. If not addressed you take the chance of dammaging the transmission, transfercase and Cat converter on that side.
SSped
DiscoMike2003
Nov 13, 2008 04:57 PM
98roverguy
Jul 17, 2007 07:44 AM
AllRover
Jun 12, 2007 04:21 PM
Doak
Oct 11, 2006 11:39 AM
Pilk
Mar 22, 2005 12:28 AM
