Drivetrain Questions
Old Jul 16, 2007 | 05:00 PM
98roverguy's Avatar
Default Drivetrain Questions
I know very little about the drivetrains on my disco 1. What sort of services need to be done to the front and rear differential, such as bearings, cv joints, hub greasing etc as routine maintanence @ 60,000 miles. I have replaced all my u-joints and am still getting a sort of moaning noise from the front right wheel at speeds over 70 mph. It is quite loud in the passengers seat, but decreases in volume significanly to the drivers seat. 75,000 miles and NO history of past maintenace. I have done maintenance in just about every area accept this one, and due to having no records, am prepared to do everything needed to get up to speed. Thanks!
Old Jul 16, 2007 | 05:30 PM
Default RE: Drivetrain Questions
Have you serviced your swivels and had them adjusted, preload setting?
Mike
Old Jul 16, 2007 | 05:43 PM
98roverguy's Avatar
Nope. What does that entail? Would there be a procedure for it in the service manual?
Old Jul 17, 2007 | 07:44 AM
Here is my list for a major at 60K.
Mike
This is the parts list for a 60,000 mile service the way I do it.
1 Oil filter , K&N 3001
1 Air filter
1 Transmission filter kit
6 Qts of engine oil
12 Qts of ATF
7 Qts of 80/90W gear oil
2 Qts of Brake fluid
2 Qts of synthetic Power steering fluid
2 Gallons of OAT, orange coolant
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platium Plus 4's
1 Set of Magnacor 8mm plug wires
1 Serpentine belt if not yet replaced
2 Bottles of SeaFoam
60,000 Mile Service
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Flush the coolant system
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
Mike
sideshow
Nov 20, 2012 07:58 PM
AllRover
Jun 12, 2007 04:21 PM
Doak
Oct 11, 2006 11:39 AM
bmartin2
Feb 18, 2006 02:49 AM
Pilk
Mar 22, 2005 12:28 AM
