driving with low voltage battery: wipers, windows, heater fan stopped working...
Old Dec 22, 2010 | 01:57 AM
twaszak's Avatar
Default driving with low voltage battery: wipers, windows, heater fan stopped working...
I was driving to Costco with a low voltage battery (15 miles or so) (had to no choice etc) to get a replacement battery. About halfway there, the red battery light comes on the dash and then the windows, wipers, radio, sunroofs, and heater fan become inoperable. A few moments later the red battery light goes away, but the wipers, windows, and everything else still don't work.
I replaced the battery, literally 7 miles and 40 minutes later (there was a line at Costco go figure), but the wipers, windows, and everything else etc etc still won't turn on or go up or down etc etc.
I tried locking/unlocking with the key three times, and clicking my heels, but this did nothing happened.
BTW: battery had low voltage because it discharged while I was taking my sweet time changing out the head gaskets etc etc. (Alternator tests fine etc etc.) The battery voltage had dropped so low that the alternator couldn't recharge the battery and provide enough juice to power everything. When the battery voltage gets too low everything shuts in order of priority etc.
I'm guessing that when the voltage got too low, the Disco's brain started shutting things off so the vehicle would still drive etc. I'm guessing if that's the case, then something needs to be reset to get everything working again (or something). That's what I haven't figured out yet. When the sun is up tomorrow, just to be thorough, I'll start looking for blown fuses (even though that seems counter-intuitive to me).
Any suggestions or ideas?
What works: all lights and turn signals, right and left electric mirror adjust, electric window defrosters
What doesn't: windows, wipers front and back, wiper fluid front and back, seat heaters, radio, sunroofs, heater fan, carcinogen lighter.
Don't know cuz I didn't try: AC, electric seat adjustments, cruise control, remote entry, and whatever else...
Thanks in advance.
Cheers,
Thomas
Old Dec 22, 2010 | 06:45 AM
hilltoppersx's Avatar
did the CEL come on? you should have gotten a low voltage code. does the truck start now?
Old Dec 22, 2010 | 07:59 PM
Your alternator will charge a completely dead battery if it is working correctly.
Old Dec 22, 2010 | 10:55 PM
twaszak's Avatar
Default update...
realized this morning that my multimeter is flaky and unreliable.... that means the results from when I tested my alternator last night are crap and bogus...
I'm going to concentrate on my alternator before I try to track down the other stuff... I'll pull it and get it bench tested tomorrow (hopefully)
new battery ran down as well... needed a charge and boost to get started today... seems to point to alternator issues...
error codes.... I got a P0526 and a P1526
Old Dec 23, 2010 | 03:40 AM
twaszak's Avatar
Default oops... typo
sorry I meant P1562 and P0562
Old Dec 23, 2010 | 06:50 AM
go to an autozone or similar they will test the alternator for free. sounds like the alternator is shot.
Old Dec 28, 2010 | 01:37 PM
twaszak's Avatar
Update:
Alternator was crapped out and pushing out only 11.52 volts....
Replaced it with an $85 used 150 amp Bosch alternator from a 99 Range Rover that I was lucky enough to find locally. I tested it then installed it and all is good.
Thanks for everyones input.
Case closed.
tsuyoi
Sep 22, 2020 10:37 AM
vonrock
Feb 12, 2015 08:16 AM
yfdreserve
Jan 12, 2013 06:37 PM
caneraiser
Oct 27, 2012 07:35 AM
jlwhite3
Nov 16, 2010 06:15 PM
