Driving With No A/C Refrigerant
Old Aug 16, 2013 | 07:10 PM
ProRiderRoadKing's Avatar
Default Driving With No A/C Refrigerant
I am planning on replacing the A/C lines on the firewall, but don't have the equipment to properly evacuate the system. To save paying a shop to remove my intake and swap the lines, which I can do, I want to have the system evacuated, do the necessary work at home, then have the system professionally recharged. As far as i understand, if I unplug the A/C compressor it will just act as a simple pulley and be fine to drive with no refrigerant in the system. Is this correct? Thanks
Old Aug 16, 2013 | 07:46 PM
Yes. Unplug compressor. As for the HVAC work, having it open to outside air will likely spoil the drier, add that to the list. Driers absorb water vapor, so even leaving them open on the test bench for a few minutes can kill them, they are sold sealed, usually in a stiff shrink wrap. Might want to have shop do drier as well when they vacuum down and recharge the system.
Old Aug 16, 2013 | 08:06 PM
Good to know, thanks. I've decided to try and tackle the rear A/C retrofit. So far it's been....expensive I'll be sure to take lots of pics and do a write up if I'm successful.
Old Aug 16, 2013 | 09:13 PM
You will have to have the system pumped down by a shop, add oil and 134 all at the same time.
Old Aug 16, 2013 | 11:48 PM
EVN137's Avatar
IIRC if your AC is very low or has no charge, the compressor is disabled by a switch. However, there is no harm in electrically disconnecting your compressor. Ditto on Savannah's drier suggestion.
Ed
Oasisplayer311
May 30, 2015 08:44 AM
EstorilM
Jan 29, 2014 08:56 AM
Duke
Jul 21, 2013 05:04 PM
Dan02
Apr 10, 2011 04:11 PM
mikemeyer0
Off Topic
Aug 24, 2005 01:53 AM
