Drivw shaft tools
Old Jan 6, 2017 | 11:37 AM
LR03NJ's Avatar
Default Drive shaft tools
What size is the star looking bolt head? I just want to get that piece instead of entire set. Is that the first to be removed? Then the bolts behind it? Thanks
Old Jan 6, 2017 | 12:57 PM
Jeff Blake's Avatar
Front drive shaft does not have star/torx bolts. They are 9/16" for head and nuts (4 per side). The drive shaft tool from AB was useless for me, maybe because I have a Tom Woods. You need 2 or 3 styles of 9/16" box wrenches. Ratcheting heads are usually too big. Cheater bar to put over the wrench. A socket wrench only fit on the front 4 bolts for me.
I haven't touched the rear shaft yet
Old Jan 6, 2017 | 01:07 PM
chubbs878's Avatar
a 1/2-inch drive impact wrench makes all the difference in the world for removing the driveshaft nuts.
Old Jan 6, 2017 | 01:55 PM
jastutte's Avatar
i used two socket wrenches to remove the front drive shaft. i could not get a ratchet socket to fit. don't remember the size off the top of my head, but they were metric. you will need to be able to spin the drive shaft in order to get to all the bolts on the rear most part of the front drive shaft. i just had my son help me roll the truck back a couple of inches to rotate the drive shaft enough to reach the bolts.
Old Jan 6, 2017 | 02:15 PM
abran's Avatar
Buy the driveshaft tool from Lucky8. It has thin walls so it fits against the driveshaft.
Old Jan 6, 2017 | 02:35 PM
OffroadFrance's Avatar
X1 Abran, totally agree. I use one of these which no doubt is the same or similar, they work a dream on the driveshaft nuts and bolts.
https://www.jgs4x4.co.uk/land-rover-...-drive-ba3138/
Old Jan 6, 2017 | 09:52 PM
LR03NJ's Avatar
Here is the bolt I am referring to. It could be a 12 pt but not sure exactly which can fit there.
Do you think that once those were removed, i can drop the end part of the front shaft already? Thanks
Old Jan 6, 2017 | 09:54 PM
Luckyjayb's Avatar
A good closed enc wrench or ratchet wrench should work. You might have to break it loose with a closed end wrench with a cheater wrench on it but it shouldn't be too bad
Old Jan 7, 2017 | 12:40 AM
number9's Avatar
Yup, a 12pt combo or box end wrench should fit. 12pt 3/8 drive socket with a wobble extension might work as well.
DavC
Jul 16, 2023 08:26 AM
Tvdmtac
Sep 5, 2007 09:42 AM
billinohio
May 19, 2007 06:18 PM
D2 2003
Mar 16, 2007 11:31 AM
