Dual Timing chain set, will it fit in housing?
Old Apr 23, 2017 | 05:14 PM
earlyrover's Avatar
Default Dual Timing chain set, will it fit in housing?
In earlier, 1995, Range Rover, I installed an Edelbrock dual timing chain gear set, with no problems, and ran it on that engine rebuild for over 100,000 miles. So now for my 2004 Discovery 2, I am considering doing the same, because the dual chain stretches way less than a single chain set, BUT, I don't know if that dual chain/sprocket set will fit inside the front cover, that functions as housing for water pump, for oil pump gears, and at the same time, covers up the timing gear set. HAS ANYONE DONE THIS, USED A DUAL SET INSIDE THAT FRONT COVER, WILL IT FIT AND RUN FINE IN THE COVER? THANK IN ADVANCE.
A5scott
Jul 11, 2015 07:25 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
BajaXJ92
Nov 13, 2009 05:00 PM
FTB 2000 Disco
May 15, 2007 07:49 AM
mrach21061
Apr 25, 2007 11:54 AM
