E-Brake Question
I removed my center console today and had to disconnect the e-brake to do so per Rave. Well I'm trying to put everything back and I'm having an issue. The gears for the hand brake will not stay engaged. I can get them to click together but as soon as I press the button to release the brake it stays separated and doesn't return to the other gear. I'm not sure if I'm explaining this clearly enough but it's almost like a spring should be in there to return the gears together to lock. Anyone have experience with the hand brake?
Thanks
Thanks
Thanks
Thanks
FYI emergency brakes have gone the way of the dodo. They are now referred to as the parking brake.
I forgot to mention its a Disco I.
I usually think of them as handbrakes (handbrake slides, haha).
Well, not in the Disco's at least.
I did look and I assume that a spring would be involved but I wasn't sure. I didn't see a spring lying around but I need to check again. I figured if someone knew for sure it would clear things up a little bit.
tibyABv6
Jan 7, 2011 06:02 AM
bigbris1
Jul 3, 2007 08:02 PM
