Easiest brake bleeding ever.
Old Dec 25, 2017 | 08:23 PM
Extinct's Avatar
Default Easiest brake bleeding ever.
Just bled the brakes using this procedure: https://www.aulro.com/afvb/discovery...akes-solo.html
Easiest brake bleed ever!
Took about 1 quart of brake fluid to flush out completely.
Old Dec 26, 2017 | 11:50 AM
Friday Night Disco's Avatar
very clever! Next go around I will definitely try this approach instead of paying my neighbor in beer to pump the brake pedal.
Old Dec 26, 2017 | 12:51 PM
zuke's Avatar
That procedure lists the wrong bleed order. It goes RR, lr, rf, lf,
the rave is wrong
Old Dec 26, 2017 | 09:14 PM
Extinct's Avatar
the rave is wrong
Of course, start farthest from the master cylinder and work your way to closest.
Old Dec 27, 2017 | 10:56 AM
OffroadFrance's Avatar
I hate to pee on your parade guys but this 'solution' has been around for many years avec the same problems, however, there is one big intrinsic problem with it, it activates the the modulator pump OK but doesn't activate the shuttle valves in sequence if at all. If you search back in the forum some years ago there was copious discussion about the subject.
tweakrover
Dec 28, 2011 03:52 PM
svntsvn
Sep 7, 2011 11:33 AM
losinov
Dec 16, 2010 07:03 PM
Hare
Mar 25, 2008 01:16 PM
