Easy CPS DIY
Old Jul 29, 2013 | 05:43 PM
NiteTrain's Avatar
Default Easy CPS DIY
cut inner fender to access crankshaft position sensor
Attached Thumbnails Easy CPS DIY-hpim0733%5B1%5D.jpg   Easy CPS DIY-hpim0734%5B1%5D.jpg
Old Jul 29, 2013 | 05:47 PM
dusty1's Avatar
easy access.
so, how did the seal up go? just rivet a piece back on? any pics of reassemble?
Old Jul 29, 2013 | 05:48 PM
Bet you did that for your starter on the other side as well. Got a pix of the repaired inner fender?
Old Jul 29, 2013 | 05:53 PM
NiteTrain's Avatar
For now I just bent the fender piece back down. It's hardly noticeable except for the cuts on each side. Later I plan to use use secure it with screws. No rivets, I want to be able to access it again.
Old Jul 29, 2013 | 05:54 PM
Street Wolf's Avatar
....... So you cut up your truck to avoid doing a simple 20-minute-ish job the traditional way?
Old Jul 29, 2013 | 05:55 PM
NiteTrain's Avatar
I have not had to replace starter. For now I just bent the piece back down.
Old Jul 29, 2013 | 05:56 PM
NiteTrain's Avatar
I have been working on my own vehicles for 20 years now. If you can replace a DII CPS in 20 minutes you are a better mechanic than I am.
Old Jul 29, 2013 | 05:58 PM
Thanks.
Old Jul 29, 2013 | 06:02 PM
NiteTrain's Avatar
Thanks.
so how many have you replaced?
Old Jul 30, 2013 | 08:30 AM
Ghaniba's Avatar
I've changed mine 3x now - the last time took me 35 mins. It's definitely a job that gets easier doing it the second... then the third time. I do admit though, cutting this access isn't such a bad idea. It's adding another spot for salt/rust in New England, but that spot is the least of my worry.
Dave
