Easy question, but i cant figure it out
Old Feb 13, 2014 | 08:00 PM
FreeRideSLR's Avatar
Default Easy question, but i cant figure it out
I'm replacing the radiator on my 03 and can't figure out how to remove the coolant sensor. It doesn't seem to have any push to release clips..
Old Feb 13, 2014 | 08:41 PM
Jared9220's Avatar
If you are talking about the radiator temp sensor then it is threaded and screwed into the radiator. Just take an open end wrench and unscrew it.
Old Feb 13, 2014 | 08:52 PM
Jared9220's Avatar
Sorry I need to edit what I said above. There is a radiator temp sensor in the radiator and there is a coolant temp sensor in the manifold. The sensor in the manifold has 2 very small tabs that you can pry with a small flat head to pull out the plug, then you can unscrew it.
The sensor in the radiator just has a clip you pop off, then pull off the plug, and unscrew the sensor with a wrench
Coolant sensor.pdf
Radiator Sensor.pdf
Old Feb 13, 2014 | 09:56 PM
04duxlr's Avatar
My guess is you are having trouble unplugging the temp sensor for the SAI in the radiator. Its a pretty standard plug connection. Heres a link showing the sensor: http://www.roverparts.com/Parts/ERR2081.cfm
Old Feb 13, 2014 | 10:23 PM
Ok cool. Going to work on it again tomorrow. Just wanted to make sure before I started prying it apart. Thanks.
Old Feb 14, 2014 | 10:37 AM
SuperSport's Avatar
Nothing worse than prying the exact wrong direction and breaking your wire harness...
Old Feb 14, 2014 | 03:01 PM
Just for future reference: the connection is held together by this clip (which you cant really see from the top). It will most likely go flying across the garage...
Old Feb 14, 2014 | 03:51 PM
Jared9220's Avatar
Yep, those clips are on multiple plugs around the disco such as purge valve, injectors, IACV, and one of my favorite to deal with the 2 that connect to the coil packs. I've dropped those damn clips down behind there more then once and it is no fun fishing them back out.
Old Feb 15, 2014 | 07:49 PM
Well everything was successful. 194F idle now
Old Feb 15, 2014 | 08:04 PM
Jared9220's Avatar
Nice. That is right what i run at.
carmonalandrover
Mar 11, 2021 08:22 PM
cornbreadj
Feb 22, 2014 01:45 PM
Mojigglins
Dec 1, 2013 06:53 AM
p4nth4
Jan 7, 2012 08:07 AM
xb70valkarye
Mar 6, 2006 02:49 AM
