Easy straightforward way to add transmission fluid?
Used a pump similiar to this one, it screws onto a quart container and has a hose that goes into trans opening.
Sta-Lube Fluid Oil Grease Hand Pump - Durable ABS Plastic | eBay
The vehicle has to be running to fill. I usually put the discovery on jackstand and have rear, ever-so slightly, lower than the front, fill under fluid comes out (have a drain pan in place) and then raise the rear until a small 1/8 stream is eventually all that is coming out.
Brian.
Brian.
twin6 (04-20-2017)
Brian.
Brian.
The vehicle has to be running to fill. I usually put the discovery on jackstand and have rear, ever-so slightly, lower than the front, fill under fluid comes out (have a drain pan in place) and then raise the rear and run through the gears until a small 1/8 stream is eventually all that is coming out.
twin6 (04-20-2017)
A DI dipstick tube does not fit a DII oil pan.
----> Discovery I Transmission Dipstick Into Discovery II Photo by Innernet | Photobucket
