Easy straightforward way to add transmission fluid?
Old Apr 19, 2017 | 06:51 PM
twin6's Avatar
Default Easy straightforward way to add transmission fluid?
Can someone tell me how to easily add transmission fluid to a D2? There has to be an easy way!
Old Apr 19, 2017 | 07:23 PM
The Deputy's Avatar
Used a pump similiar to this one, it screws onto a quart container and has a hose that goes into trans opening.
Sta-Lube Fluid Oil Grease Hand Pump - Durable ABS Plastic | eBay
The vehicle has to be running to fill. I usually put the discovery on jackstand and have rear, ever-so slightly, lower than the front, fill under fluid comes out (have a drain pan in place) and then raise the rear until a small 1/8 stream is eventually all that is coming out.
Brian.
Old Apr 19, 2017 | 10:04 PM
Friday Night Disco's Avatar
Brian.
Slight edit to Deputy's post
The vehicle has to be running to fill. I usually put the discovery on jackstand and have rear, ever-so slightly, lower than the front, fill under fluid comes out (have a drain pan in place) and then raise the rear and run through the gears until a small 1/8 stream is eventually all that is coming out.
Old Apr 19, 2017 | 10:58 PM
Dan7's Avatar
Ask Paul Grant for a D1 dipstick, install and enjoy!
Old Apr 20, 2017 | 07:31 AM
jastutte's Avatar
This.
Old Apr 20, 2017 | 08:53 AM
Alex_M's Avatar
I always use a standard kerosene pump/siphon pump. The clear kind with the orange bulb that you squeeze. I use it for trans, transfer case, and differentials. A little slow for gear oil but perfect for trans fluid. Plus, they're like $4 at Lowe's.
Old Apr 20, 2017 | 11:28 AM
BackInA88's Avatar
I got a cheap pump up sprayer like this and cut the tip off.
Pump it up, insert in hole and pull the trigger.
Old Apr 20, 2017 | 02:13 PM
Externet's Avatar
A DI dipstick tube does not fit a DII oil pan.
----> Discovery I Transmission Dipstick Into Discovery II Photo by Innernet | Photobucket
Old Apr 20, 2017 | 02:21 PM
abran's Avatar
A D1 pan fits a D2 trans
Old Apr 20, 2017 | 07:07 PM
Luckyjayb's Avatar
does the d1 have a dipstick going into the pan? If so that might be next on the list
