Easy way to remove the water pump
There does not seem to be a general consensus on the best way to remove the viscous fan so here is how I did it. This only works with the belt on. These pictures are after the fact so keep the belt on. Also the Wrench is a 36mm wrench from Northern Tool, it's under $15.
1) Make a simple tool like this out of a piece of steel bracket and a bolt thin enough to fit in the spanner holes on the pulley then cut the bolt short:
![Name: 100_0310.jpg
Size: 147.0 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/47951d1501387935-easy-way-remove-water-pump-100_0310.jpg)
![Name: 100_0309.jpg
Size: 93.5 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/47952d1501387935-easy-way-remove-water-pump-100_0309.jpg)
2) Turn the pulley so a spanner hole is on the right side. Then put the spanner tool in the hole and put the wrench over top of it. Then clamp the spanner on the PAS pulley with a vise grip.
![Name: 100_0307.jpg
Size: 143.2 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/47953d1501387935-easy-way-remove-water-pump-100_0307.jpg)
![Name: 100_0308.jpg
Size: 104.6 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/47954d1501387935-easy-way-remove-water-pump-100_0308.jpg)
3) Now whack the wrench to the left with a rubber mallet:
![Name: 100_0312.jpg
Size: 88.6 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/47955d1501387935-easy-way-remove-water-pump-100_0312.jpg)
Yes any 36mm wrench should fit, the Northern Tool wrench is beefy but fit. My large craftsman adjustable wrenches are too thick to fit. It is pretty hard to get a strap wrench in there because there are pulleys all around, remove the PAS pulley and idler pulley and that will probably work with a strap wrench though you may need a 2nd set of hands.
