eBay key programming experience - FAIL
Old Feb 25, 2021 | 04:48 PM
DiscoID's Avatar
Originally Posted by Extinct
At this point your choices are the Uk keys, $150, guaranteed to work. Or used oem key circuit boards from ebay ($30 ish) + nanocom rental ($40 ish) + new ebay housing/key blanks ($8 ish) for a total of $80 ish.
Thanks for the info. Not sure what I'm going to do at this point, but it's good to know what the options are if I can't live with using the key in the driver's door.
Old Feb 25, 2021 | 06:43 PM
mollusc's Avatar
If you do want to rely on the key in the door lock, it's probably a good idea to preemptively replace the lock pin with one from Carrs4x4, or manufacture one for yourself. The stock one has a tendency to break, leaving you unable to lock or unlock the door.
Old Feb 26, 2021 | 07:46 PM
DiscoID's Avatar
Thanks. Had never heard of this issue before. Probably going to go down the replacement remote worm-hole, but in the meantime, this seems to be an easy added sense of security fix.
Old Jul 27, 2022 | 12:45 PM
XFactor's Avatar
5th Gear
Just wondering if anyone else has been able to get Ebay replacement key fobs to work or if they're still a no go? Any other reliable sources for these?
Thanks
Old Jul 27, 2022 | 02:08 PM
Extinct's Avatar
Remote Key UK work every time, although they are close to $100
Old Jul 27, 2022 | 02:27 PM
XFactor's Avatar
5th Gear
Is this the link? https://remotekey.co.uk/land-rover-k...r-1999-to-2006
Seems that its showing it as 'Discontinued'
Old Jul 27, 2022 | 06:30 PM
MSGGrunt's Avatar
Can this blank be used? It came with a parts truck I bought. Can they be taken apart and the key portion inserted into a new body and then programed?
Donor truck is a 2003 and my driver is a 2004 if that matters.
Old Jul 27, 2022 | 07:33 PM
MSGGrunt's Avatar
I just experimented with one of the donor vehicle keys and split it open. Could you order a cheap EBay blank, have it cut and swap in the old circuit board? As you can see my buttons are what have perished. Though it would be nice having a second key if the blank attached above could be programed and a "shaft" inserted.
Old Jul 27, 2022 | 07:47 PM
Extinct's Avatar
Yeah, that should work if the fob works, you will need a nanocom to program it to your truck.
Old Jul 28, 2022 | 10:42 AM
specops1526's Avatar
The blade can be purchased by itself. I forgot the part number but I bought a few a long time ago when I was adding some extra keys/replacing bent blades on my old DIIs.
