eBay Thermostat
Pushing close to 250K I just can't make myself spend $60 on a thermostat now. Last time I spent that on one I got the wrong one. Plus at my mileage and with all my electronics slowly failing in it I wouldn't be extremely upset over it. But everyone is different that's just how I feel.
Dont modify your truck beyond OEM specs, change the oil often, drive it and forget about it.
Repair stuff when they go bad, dont use snake oils, only quality fluids are needed.
Simple as that.
Amen on the oil and fluid changes. Like I tell guys about preventative maintenance (PM work), a $10 tube of grease applied when needed saves more head aches than can be fixed by a $10 bottle of Tylenol.
I firmly believe in Spike's wisdom. Fluids, Fluids, Fluids, minor mods only, and drive like you love it.
I use 15w40 rotella with a napa gold filter ever 3k miles sometimes sooner.
I have a 2in lift but don't run large tires.
The PO removed the check engine and amigos bulbs so I don't worry about it until it starts running rough.
I Don't use a temp gauge. When the aux fan started running constantly I threw in a 180 stat.
The sunroofs leak and it drips plenty of oil, but it runs like a top.
Did I mention that I've also run a K&N filter for almost 50k now as well with no problems from it? I just replace what needs replaced when I have the time and funding.
My 04 is another story. I'm ready to pull the bulbs in it and just drive. I've already removed the aftermarket gauges I installed bc I couldn't drive without staring at them the entire time.
dinandan
Jun 6, 2006 09:26 AM
beavis4g63t
Mar 14, 2006 02:55 PM
