ECU BCU & Gauge Install
Old Sep 12, 2016 | 07:35 AM
zuke's Avatar
Default ECU BCU & Gauge Install
I am looking for any last minute advise on install as I got my parts in the mail. I have read through the forums and found that I need battery unhooked, need to push hood switch in when reconnecting battery, and turn key to position 2 for ten minutes after install to sync with the IDM.
Is there anything else that I should be aware of?
Old Sep 12, 2016 | 08:19 AM
nickm347's Avatar
I'm pretty sure you'll need to perform the "EKA"
The steps are outlined here:
https://landroverforums.com/forum/di...05/#post279129
Old Sep 12, 2016 | 08:24 AM
zuke's Avatar
Default Eka
I believe that would only be needed if the donor vehicle had been immobilized.
Old Sep 13, 2016 | 10:02 PM
toofaroffroad's Avatar
Get a nanocom.
Old Sep 14, 2016 | 06:15 AM
zuke's Avatar
It was installed. I let it sinc up with the IDM for 5 minutes then fired it up. It fixed another problem that I had with the key not coming out of the ignition. I thought that was a bad xyz switch so I lucked out.
floundering
Jul 7, 2015 04:53 PM
BIGTSV
Dec 20, 2013 07:23 AM
cphillips.ia
Jan 5, 2013 07:54 AM
sickws6
Jan 8, 2012 12:48 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
