ECU BCU & Gauge Install
I am looking for any last minute advise on install as I got my parts in the mail. I have read through the forums and found that I need battery unhooked, need to push hood switch in when reconnecting battery, and turn key to position 2 for ten minutes after install to sync with the IDM.
Is there anything else that I should be aware of?
I'm pretty sure you'll need to perform the "EKA"
The steps are outlined here:
https://landroverforums.com/forum/di...05/#post279129
It was installed. I let it sinc up with the IDM for 5 minutes then fired it up. It fixed another problem that I had with the key not coming out of the ignition. I thought that was a bad xyz switch so I lucked out.
cphillips.ia
Jan 5, 2013 07:54 AM
