electric fan
Old May 23, 2013 | 12:30 PM
drowssap's Avatar
so if you put power directly to the fan motor it will run???
if so then your problem is here :
The engine coolant temperature sensor sends an input on a G wire to pin C0636-22 on the
ECM.
The engine coolant temperature sensor is earthed on a RB wire to pin C0636-21 on he ECM.
The sensor is located down on the block, to the rear left side of the AC compressor.
Old May 23, 2013 | 02:45 PM
Weaselcossey's Avatar
3rd Gear
Yes the fan will run, it just doesnt seem to run when its supposed to. So is this where I change the sensor and see if I get results?
Old May 23, 2013 | 03:28 PM
Fan is single speed, so sensor won't make it run any faster.
You see it spinning at crank up because viscous clutch is fully engaged and main fan is sucking as hard as it can. As truck warms up the fan roar drops off and the main fan slows.
The sensor that runs the electric fan is the same sensor that runs the dash heat gauge.
Old May 24, 2013 | 06:01 AM
There is a relay and fuse involved, F5 (40 amp) in under hood fuse box, and the relay number 4 in same box. You could swap relay 3 & 4 (head lamp wash). The ECU simply supplies a ground to command the relay on. It will get $$$ if the ECU is bad on that particular output. Jumping the wrong contacts in the relay base could burn circuit board traces off inside the ECU or take out a semiconductor device assigned relay driver duty. The ECU is built to switch on the mighty relay coil, which is not anywhere close to the inrush amps of the fan motor.
Old May 13, 2015 | 08:33 PM
rreinholt's Avatar
Default Electric fan fuse blows
Been following the thread because I found my fuse blown. Put a new one in and aft 15-20 minutes at idle and 195f on ultra gauge the fuse blew again. I'll check if the fan is locked up. If no, what do I do next. I'm not an electrical guy.
Old May 13, 2015 | 08:43 PM
rreinholt's Avatar
Spins freely 1/2 around the is very hard. Assume I have a bad fan. Is it difficult to replace?
Scharfire
Jul 6, 2021 02:59 PM
jafir
Feb 10, 2017 11:08 AM
vonfonk
May 6, 2006 06:50 PM
mikemeyer0
Mar 30, 2005 03:12 PM
