Electrical fault
Old Jan 9, 2020 | 09:52 AM
Chris de Bruyn's Avatar
Default Electrical fault
Need advice. I have an automatic dico 2. I had to move with a truck so to a immobiliser problem I am sorting out. All lights and dash display was working fine. Now all is dead. I checked the battery and terminals, all is in perfect condition. No fuses are blown and all relays are good. Where else do I need to start looking?
Old Jan 9, 2020 | 10:40 AM
Sixpack577's Avatar
If you know you have an alarm/ignition immobilizer problem, I would have it turned off in the ecu with a Hawkeye or Nanocom diagnostic tool.
The immobilizer is known to cause issues.
A forum member here rents a Nanocom by mail.
Old Jan 9, 2020 | 12:31 PM
JUKE179r's Avatar
If all is dead then how is the battery in perfect condition? ReCheck your battery cable wiring and the fuse box again.
Old Jan 9, 2020 | 12:51 PM
Jason Feuerstein's Avatar
Start at the battery and work your way back until you find a connection where there should be 12V and isn't. If everything is dead, then it's probably either the battery cable or the engine fuse box itself.
Old Jan 9, 2020 | 10:59 PM
I removed the battery and had it tested. I will take your advise and work it back. I live in namibia and can find no one with an dianostic tool locally. Not even the Landrover agent locally has one anymore. Any suggestion where I can maybe find one online? I
Old Jan 10, 2020 | 10:35 AM
To be honest, I don't know if any of the people who sell diagnostic tools will deliver to Namibia. You can look on Ebay for either a Nanocom or a Bearmach Hawkeye, but I'm not sure how it would get to you.
PeetzLR3
Dec 11, 2023 11:21 PM
aemnky606
Nov 12, 2016 11:38 AM
oilspotLR
Aug 21, 2012 09:55 AM
rlrigsby
Apr 2, 2012 03:15 PM
FTB 2000 Disco
Dec 4, 2006 12:03 AM
