Electrical Problems
Electrical Problems
So i went off roading last week ..it jarred it pretty good, and then a couple days ago my truck dies while pulling into my street. today I swapped out the fuel filter and battery. it started up and i drove it home, then it stalled again. but it restarted and i got it home.
So I think its electrical..could something have been jarred when i was off roading? where would i look ..
ive also got to gert the codes read at auto zone or advance.
any advice would be extremely helpful.
humbly,
mv
ps, where are the ground points for the DI?[align=right][/align]
CarolinaBlue
View Public Profile
Send a private message to CarolinaBlue
Find all posts by CarolinaBlue
Add CarolinaBlue to Your Buddy List[/align]
[/align][align=center]
[/align][/align][/align]
humbly,
mv
CarolinaBlue
View Public Profile
RE: Electrical Problems
http://www.roverparts.com/TechTips/g...l_problems.cfm
When the truck is running how well does it run? Does it idle at 600-750 rpm? Does it idle smooth? Does the tach work?
I am leaning towards the stepper motor, also known as the idle air control valve.
When it fails the truck will not idle, easy to replace.
http://www.roverparts.com/Parts/ERR4352.cfm
http://www.roverparts.com/Parts/ERR5199.cfm
Not knowing what year your truck is I included the link for both.
I have heard but cannot conferm that the IAC from a Jeep will work and is much cheaper and can be had at AutoZone.
You might beable to get the LR one there too.
You can take yours out and clean it with carb cleaner and a tooth brush, clean the hole it goes into also.
Just wanted to throw this in the mix, maybe this confirms that the IAC is what I might need rto replace. A couple times within the last month I have started the truck(97 D1) and it has idled too high..around 2k rpm and then it will eventually return to a "normal idle" below 1k. I didnt think to include that with my original post.
