Electrical Problems
http://www.green-oval.com/joomla/ind...&Itemid=29
Download your model, which is a DI, this IS THE shop manual for Rovers.
Installed a new IAC that I picked up at Advance. Still didnt do this trick. WOnt hold an idle...I srpayed engine starting fluid several times and each time it cranked and came to life at ab 2 to 3k rpm but then dies, didnt hold an idle. any thoughts.
Downloading the RAVE CD now. when it finishes downloading do i open it with the alcohol 120 program?
Thanks so much for your help, it is greatly appreciated.
yes sir, with carbuerator cleaner. what length should i adjust the IAC to, the box from Advance said 1 1/8th inches. it was a GP Soreson 21774 779-10153. got the truck to hit ab 2k rpm with engine starter but wud only do that when engine starter was sprayed in intake. wudnt idle on its own.
