Electrical Troubleshoot
Old Apr 24, 2023 | 02:57 PM
Hughjasknuts's Avatar
3rd Gear
Default Electrical Troubleshoot
Hey,
I drove my 2002 Disco through some water wasn’t necessarily deep but it was splashing underneath my vehicle a good bit. I think (not sure this is where I need help) my gear position switch and my selector lever assembly aren’t communicating properly. Any time I put the car into drive the red light on the selector lever isn’t turning on, nor is it fully engaging the drive gears nor is the D on the instrument panel showing up. I then go neutral the N shows up, the red light on the selector lever is on, same thing when I go reverse the R shows up, the red light is on, but then I get a steady HDC (hill descent control) light along with a flashing green M and S lights indicating manual and sport mode selected, even though I never changed the mode.
Anybody ever had this issue, or know where I can start troubleshooting? IE how do I get to the pins on the contact to measure the 12V output signals sent from the Cable of the Selector lever to the gear position switch? and or and I use the ECU to measure the input from the Gear position switch to see what’s going on?
Could it be some sort of issue I’m overlooking?
I looked underneath and it all looks dry, but I have a feeling water may be shorting something. I don’t have easy access to the gear position switch so if anybody knows a way any help would be appreciated.
Thanks in advance for your time!
Old Apr 25, 2023 | 11:03 AM
Richard Gallant's Avatar
@Hughjasknuts Could be the XYZ switch underneath, it communicates with the transmission computer. M & S on at the same time can also indicate an XYZ issue. But the HDC is odd, sounds like you got a lot of water somewhere.
1 thing on water crossings, fast looks cool but always creates problems. Slower is far better.
Old Apr 25, 2023 | 07:35 PM
Extinct's Avatar
I would start with the XYZ switch, the HDC also indicates you may have some transfer case switch issues.
Rrr_bhb
Jan 16, 2023 02:45 PM
NZPablo
Jan 12, 2023 07:05 PM
JRAM
Dec 21, 2015 11:40 AM
kdscott100
Apr 15, 2014 12:41 AM
Nathan King
Dec 30, 2013 01:07 PM
