Electronic Brake Controller Wiring Question
Old May 29, 2009 | 09:01 PM
MarvelVT's Avatar
Default Electronic Brake Controller Wiring Question
I am wiring a brake controller for my trailer brakes. It instructed me to connect to the cold side of the brake switch, which I interpreted to mean 12 volts when the brakes are on. One of the four wires did indeed give 12 volts when the brakes/ignition were on so I chose that one. Driving around tonight my brake controller randomly came on as if I were hitting the brakes when I actually wasn't. Additionally I can hear a factory relay under the dash clicking when I hit the override braking button on my controller (which shouldn't be happening).
Has anyone hooked up a brake controller and if so which wire did you use?
Thanks
Old May 29, 2009 | 11:13 PM
antichrist's Avatar
I recently put a Tekonsha P3 in my Disco. I connected Red controller wire to the Green/Purple brake wire.
This is for my Disco
Vehicle side of 7Pin Trailer Socket: (second colour is trace)
Black - Ground
Red/Orange - RH Tail
Green/Purple - Stop Lights
Green/White - RH Indicator
Green/Red - LH Indicator
Red/Yellow - Rear Fog
Red/Black - LH Tail
Single Pin Socket A:
Green/Brown - Reversing light
Single Pin Socket B: 20A fuse F6 in Satellite 2 (I think)
Purple/Brown - Power
rickroverover
May 17, 2014 11:23 PM
evansjoem
Feb 16, 2014 06:49 AM
Shark59
May 15, 2013 05:39 PM
DWB
Jul 24, 2012 04:55 AM
Our1stDisco
Apr 3, 2008 08:50 PM
