EMERGENCY HELP
I need some in a bad way!!!! I have just completed an 1100 mile trip[ and I get to watertown NY, and I have a bad coolant leak at the thottle body where the two hoses connect. It is not a hoses leaking but the part of the body right above where ther do connect. Question that I have as I have not attempted to take this apart, is that piece a solid body or could this be a gasket? i will not have internet access for a while after this so if someone could sms with a number or call me @ 205-222-4438 and I can then call you back as i would not anyone to have long distance charges.
From my understanding, it's a gasket...like this: http://www.roverparts.com/Parts/ERR6623.cfm
I have the same issue on my '03 Disco II, just not as severe. I would love to see more on this post as I'll be replacing it soon too...
This is what you need. Coolant leaks just above the two hoses going into it and down onto the rocker cover and exhaust manifold. The other gasket shown by jrkstore43 just seals where the throttle body meets the intake - there is no coolant there. Here is your part. I just replaced mine for the second time in a year and a half. takes about 15-20 minutes. http://www.roverconnection.com/Disco...GM000010K.html. hope this helps.
Aaron
2003 SE7 89,000 miles.
Aaron
I think that gasket is mis labeled it looks like a throttle body gasket to me, not a TB heater gasket. Here is the TB heater kit. http://www.roverparts.com/Parts/MGM000010KG.cfm
Willie
Willie
Just wanted to thank everyone for their help, and this might not have seemed to much of an emergency but in my mind and where as was at the time. Just a bad situation but I have made it home
ciablackops
Nov 14, 2010 02:59 AM
