Engine
I gave up trying to fix my 2000 Disco's overheating engine so I bought a use engine out of a 2001 Disco 77,000 miles. Since it's sitting in my garage I figure now is the time to do any repairs and updates on it. I'm looking for suggestions as to what should be replaced, checked, or improved, if more than one suggestion please list priority first. Thanks
Everything as mentioned so far, except the timing chain which is not needed for another 100,000 miles plus.
Add new plugs and 8 mm wires, an up-dated upper radiator hose that has the bleed screw in the black tee not the hose, and a bottle of either Water Wetter or Purple Ice to the coolant, and a front tranny seal. Make sure
For the fun things, a 4.6 cam with heavier springs for better performance and a CDL linkage so you can enjoy all the extra traction.
Thanks, My list looks like this, head gasgets, water pump, t-stat, seals, plugs wires, rad checked, updated bleed hose, I've never done a front gasget seal and I'm not familiar with CDL linkage can you give me how to do advice? How much more HP and or Torque would a 4.6 cam and stiffer springs give me? Also, what about oil pan gasgets, lifter, rods, or how ofter do those crank and cam shaft sensor go? Thanks, again.
jlester@mt.gov
Mar 26, 2008 09:30 PM
tcbinaflash
Jan 8, 2008 04:23 PM
miishmiish
Mar 8, 2006 12:31 AM
