Engine bay explosion, oil, coolant, the works
Old Nov 10, 2019 | 12:42 PM
  #21
Banzai Jimmy's Avatar
On the mountain driving topic... while I won't spin mine to 4,500 rpms on the highway, I do go to 4,000. I stick to the right lanes and try to maintain 55 mph when on the highways in the Colorado mountains. Mine's a 5-speed, and I find I have to drop from 4th to 3rd to get the rpms up enough (up to 4,000) to get the speed back up to not be the slowest vehicle on the road, then go back to 4th for as long as I can. My rig is way overweight and almost re-geared to stock (it's a touch under what is needed, so that doesn't help), so it's a struggle. Having a dizzy motor is a help, as I have the base timing bumped up to help with the power loss and find that I'm not downshifting as much as I did with the base timing set to stock.
Old Nov 12, 2019 | 09:57 AM
  #22
Broken08's Avatar
Originally Posted by cfz2882
fan clutch is probably still good.for a fan blade;
-Dorman 620-112-this is white plastic and a Ford design used on the Aerostar and other vehicles
So is this fan better for some reason than a sick replacement? Does it bolt right on to the clutch?
Old Nov 12, 2019 | 10:26 AM
  #23
Sixpack577's Avatar
Here's the fan and fan clutch Best4x4 reccomends.
Several of us have his mods, as he's done all the leg work for us, and they work great.
I think I paid $60 for both(bought seperately, do not come together, and you'll need 4 nuts or bolts from a hardware store).
Old Nov 12, 2019 | 10:31 AM
  #24
Broken08's Avatar
Is there a link or part numbers? Sorry for my ignorance!
Old Nov 12, 2019 | 10:36 AM
  #25
Brandon318's Avatar
Can the 2004 fan swap directly over to a 2002?
Old Nov 12, 2019 | 11:01 AM
  #26
Sixpack577's Avatar
Doorman fan # 620-112
Hayden fan clutch # 2991
Old Nov 12, 2019 | 11:02 AM
  #27
Sixpack577's Avatar
Yes, all the 4.0/4.6 Bosch is much the same
Old Nov 12, 2019 | 11:17 AM
  #28
Broken08's Avatar
Cool. That's the clutch I already have so I'll grab that fan and hope it doesn't blow up.
Old Nov 12, 2019 | 11:35 AM
  #29
Richard Gallant's Avatar
@Broken08 I have that fan (white one) and due to a shroud bolt backing out it hit the shroud. Not significant damage to the shroud, the fan just picked up some black plastic. Not saying you would not have significant damage if something got into the blades but they seem pretty durable.
Old Nov 12, 2019 | 11:37 AM
  #30
Sixpack577's Avatar
I put medium Loc-tite on mine.
And, the new plastic is flexible.
The stock fan is 15-20 years old, baked and brittle.
