Engine Codes
Old Jan 27, 2008 | 02:21 PM
ccvalentino's Avatar
Default Engine Codes
Just read my codes for my check engine light and got the following:
P0447 and P1668 Pending. P0447 refers to a Vent Control Circuit Open.
Any thoughts are greatly appreciated.
Thanks,
Chris
Old Jan 27, 2008 | 04:21 PM
okdiscoguy's Avatar
Default RE: Engine Codes
I believe your vent control is on the filler neck... Code says the circuit has an open..
check out www.iequus.com for code defs...
The other is your alarm
Old Jan 27, 2008 | 04:25 PM
I think it pretains more to the evap system canister area more then the fuel cap, the 1668 I can't find.
Old Jan 27, 2008 | 04:30 PM
wesk's Avatar
P1668 = Anti-Theft Alarm serial link fault Drive cycle A:Signal out of range - above maximum.
However, I have no idea what it means.
Old Jan 27, 2008 | 04:33 PM
Thanks...Anyone have a fix for this? Does the solenoid need to be replaced?
Chris
Old Jan 27, 2008 | 05:18 PM
On the evap system you need to talk with a mechanic for the testing procedure, scanneer may clear the 1668 with no repairs.
NWROVERS
Mar 10, 2015 03:17 PM
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
