Engine Codes
Old Aug 22, 2007 | 01:06 PM
bigugly82's Avatar
Default Engine Codes
inserted from prev post:
I was sitting in my '03 Rover about 44K miles at a stoplight with the AC running and felt the engine being a little more active than normal.
My RPM's stay consistant but it almost feels like I'm running rich. It kind of sounds like my RPM's are jumping a bit but they don't. It's a bit louder with the AC's running but you can still hear it when the AC's off. You can also feel it slightly in the brake pedal. One more thing, my Check Engine Light just came on. And I feel it more when it's in gear. If I'm in park and neutral you can hardly feel it. But once in drive or reverse or with the AC on it's more noticable.
AND HERE ARE MY CODES:
P 0300
P 0301 -pulling twice
P 0306 -also pulling twice
P 1300
P 0441
What should I do next. Plugs and wires or flush and see what happens?
Do I run the risk of damage if I can't get it fixed until this weekend?
-Thanks
Old Aug 22, 2007 | 01:18 PM
okdiscoguy's Avatar
Default RE: Engine Codes
Plugs and wires ASAP. Go with the good ones. 8MM Magnacor's are highly recommended. Call Mike and get a # from him. He knows a guy......
The first ones are mis-fires.
The last one is
P0441
Generic
Evaporative Emission System Incorrect Purge Flow
NWROVERS
Mar 10, 2015 03:17 PM
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
