Engine codes need some help
Old Nov 3, 2007 | 03:37 PM
philhan's Avatar
Default Engine codes need some help
Hi All:
I got my codes read off an OBD II scanner and got these:
P0302--Cylinder 2 misfire
P1415--Manufacturer Control
P1319--Aux. Emission Controls
Any ideas on what to look at/replace? Thanks in advance!
Old Nov 4, 2007 | 11:04 AM
Default RE: Engine codes need some help
How many miles on your engine, has it ever been tuned, what octane gas are you using?
Old Nov 4, 2007 | 12:45 PM
philhan's Avatar
Hi Mike:
The car has a little over 86,000 miles on it. I believe the last time the plugs were changed was at 60,000.
I always use 91 octane. The car still idles and drives perfect. I cleared the codes yesterday and they came back on today. Any ideas?
Thanks again!
Old Nov 4, 2007 | 02:09 PM
I believe that if you get rid of the old plug wires, going to the Magnacor 8mm wires, you will loose the misfire code and once it is gone the others will drop off.
DiscoShelt
Dec 17, 2014 01:11 PM
DiscoIIBrandon
Mar 11, 2011 12:01 PM
Billabong
Jan 27, 2010 12:36 AM
97DISCOIDAHO
Sep 8, 2006 11:56 PM
