Ok, my research isn't turning up anything and I need some help with engine codes.
Old Feb 28, 2015 | 07:07 PM
Alex_M's Avatar
Default Ok, my research isn't turning up anything and I need some help with engine codes.
My truck is running fine. It's had the 3 amigos (intermittent) since I bought it a year and a half ago. The check engine light does sometimes show a p1590 at the same time, but not always. Here are the codes:
P1590 (intermittent)
P1170
P1174
P0441-Purge Valve
I did replace the purge valve a few months ago, but I didn't use the OEM or the Hyundai part, I used a different one that is evidentally known to fail. I've also still got the factory original MAF at 135k miles, though all 4 O2 sensors have less than 3k miles on them.
I should note, the 3 amigos went away for quite some time on two seperate occasions. Once for several weeks after I replaced my front driver wheel bearing. Second for a couple or three weeks after I had my head gaskets and other extensive engine work done.
Any ideas? My first though is just replace the MAF and Purge Valve, but I'd like to get a second opinion before I drop $200 on a guess.
Old Feb 28, 2015 | 07:30 PM
ralphobell's Avatar
You say you replaced the front wheel bearing. Do you mean front hub?
Old Feb 28, 2015 | 07:52 PM
Alex_M's Avatar
Righto, the bearing was going out so I replaced the whole front hub assembly/axle seal/axle nut combo.
Old Feb 28, 2015 | 07:57 PM
Alex_M's Avatar
Oh, and I forgot to add, I've got a driveline vibration that shakes like a mother sometimes. I think it's caused by a bad tie rod end which I'm replacing soon, so that might clear up the ABS fault. I hope.
Old Mar 1, 2015 | 01:40 PM
dusty1's Avatar
My first thought is look for vacuum leaks and exhaust leak. Then purge
Old Mar 1, 2015 | 02:45 PM
Alex_M's Avatar
Thanks Dusty. I do have a minor pre-cat exhaust leak. I was ignoring it till I installed headers and got a custom y-pipe.
I'll check for vacuum leaks too.
Old Mar 1, 2015 | 03:07 PM
dusty1's Avatar
well that can give you the 70's
BritishByProxy
Freelander
Aug 2, 2011 02:05 AM
StormTroopa
Aug 9, 2009 05:26 PM
BYURover
Jul 12, 2007 09:27 PM
