Engine cut out! Help!!
Old Dec 17, 2007 | 06:20 PM
mooal5's Avatar
Default Engine cut out! Help!!
I have a 96 discovery 103k and i have cut out or flat spot issues. I have just replaced plugs and wires to correct the issue but it is still occuring. It seems to happen going up a hill under load. Just seems like power loss. She still makes it up the hill but wont gain speed. when i press the gas down stays the same. I have also been having problems at restart after short stops 5-10 min when engine is still hot. may take a couple times to start then rough idle sputter like flooded or somthing. I have been told mabe they are related? Any help would be great. Thanks!!!
Old Dec 17, 2007 | 06:33 PM
Default RE: Engine cut out! Help!!
Start with replacing your fuuel filter then get back to us.
Old Dec 17, 2007 | 07:28 PM
mooal5's Avatar
Will do! I have a new one but was fighting the bracket to get the old one off. Will replace tomorrow.
Old Dec 18, 2007 | 11:34 AM
Use lots of penetrating fluid to break the fittings loose.
pgaukroger
Feb 29, 2016 05:56 AM
assafde
May 12, 2015 03:09 PM
brian4d
Mar 16, 2009 09:56 PM
mbrummal
Feb 25, 2007 03:07 AM
