Engine cutting out on me.
Old Jul 10, 2016 | 04:51 PM
Freedom38's Avatar
Default Engine cutting out on me.
So for the past while my 2003 feels like it's low on power/ engine cutting out/ engine stuttering. When I put a fuel pressure gauge on it for about three days I had it on it never stuttered or cut out so the fuel pressure was constant. The fuel psi was around 48-50 psi. I can't figure this out. I want to say it's the fuel pump but I don't know.
Old Jul 10, 2016 | 07:11 PM
disc oh no's Avatar
Does it have any trouble codes?
Old Jul 10, 2016 | 09:44 PM
Freedom38's Avatar
None, this also does not help me.
Old Jul 12, 2016 | 06:55 PM
disc oh no's Avatar
I had a fuel pump go bad in an old minivan I had and it never gave me any codes either. That seems to be common on many vehicles. Also, crank position sensors often give no codes when they start to act up. Sometimes they go completely dead and never give a code.
With your fuel pressure readings looking good, the CPS might be a good direction to look. When the CPS signal stops, the computer thinks the engine is not running, basically. It will shut down the fuel pump, ignition and injector pulse.
Old Jul 12, 2016 | 10:07 PM
Tracker1996's Avatar
Check the hard plastic vacuum line coming out of the right hand side of intake manifold, trace it back making sure there aren't any breaks, Check to make sure your intake bolts are tight and lastly I would attempt to clean MAF sensor.
Old Jul 12, 2016 | 10:40 PM
disc oh no's Avatar
These are all good things to check too. Much better to check and/or clean things than to throw a bunch of parts at it.
Paul Taylor
Nov 25, 2015 12:31 PM
A Team
Nov 13, 2007 08:45 AM
ChrisW6
Sep 29, 2007 12:26 PM
westernsun
May 27, 2006 04:24 PM
landrover
May 14, 2006 12:20 PM
