Engine flush
Old Sep 14, 2009 | 04:47 PM
  #21
demonlarry's Avatar
Originally Posted by ColoDisco
I am a mechanic and have been working on cars for over 20 years. I use BG oil flush. And having done research on this am putting a can in for 2 full fuel tanks prior to actually changing my oil. This gives it plenty of time to fully break down all of the sludge particulates.
We did this with a 15 year old Jetta when I worked at the VW dealer and tore down the engine. It was immaculate inside. The can itself recommends running the vehicle for 20 minutes at 2k RPM's however if you have a really neglected engine do what I say.
I have actually experienced 40 more mpt during this process and am only a week away from doing my oil change.
BG makes great products... their gear oil is awesome. the brake dressing is awesome!
Old Sep 14, 2009 | 07:03 PM
  #22
ColoDisco's Avatar
I swear by BG products and use them in my own shop.
Old Sep 15, 2009 | 10:22 AM
  #23
I am a 20 plus year believer/user of many of the B&G products and machines with great results.
Old Sep 15, 2009 | 08:39 PM
  #24
demonlarry's Avatar
we used them exclusively at the VW dealerships I've worked at.
never had a problem.
Old Sep 15, 2009 | 08:48 PM
  #25
oysterhead's Avatar
The B&G Quick Clean, right?
Old Sep 16, 2009 | 09:46 PM
  #26
Disco-Nate's Avatar
so Gunk makes an additive that you put in with your oil, run it for a while then change the oil, is that a good idea?
I have just read things about if I do too much of a clean all at once I might discover some oil leaks that were clogged before. I don't know the history of the oil changes and don't want a bigger problem than I can handle all at once. this weekend I will for sure be changing the oil and I was thinking of using the gunk product, changing the oil and filter with cheaper ones, than in 1000 miles doing another oil change and going to synthetic and a much better filter. any suggestions?
Old Sep 16, 2009 | 09:50 PM
  #27
oysterhead's Avatar
why go from gunk to crappy oil and filter?
why not straight from gunk to syn?
Old Sep 16, 2009 | 09:57 PM
  #28
Disco-Nate's Avatar
I was thinking cheaper oil and filter to help clean the engine out a little more after the gunk, and then after a little driving (500-1000 miles) re-change the oil to synthetic and high end filter for a normal oil change cycle.
No?
Old Sep 17, 2009 | 01:31 AM
  #29
mattrickman's Avatar
Just go straight to synthetic. Then do another change after 500-1000 miles. (Depending on how much you drive).
wannabe
Jan 24, 2011 10:42 AM
tsuami1
Jul 4, 2010 05:25 PM
Baylink
Nov 7, 2009 08:49 AM
tunernewb92
Jun 23, 2009 04:44 PM
mellyagaunce
Sep 19, 2008 09:16 AM
