Engine Knocking and Engine Flush
Old Sep 18, 2008 | 06:57 AM
mellyagaunce's Avatar
Default RE: Engine Knocking and Engine Flush
The best way I can describe the sound is if you were to wrap one knuckle on a small piece of wood. I just did it and it's only slightly higher in tone than the actual sound the engine is making.
Old Sep 18, 2008 | 07:12 AM
Landzu's Avatar
ORIGINAL: CandiMan
ORIGINAL: Landzu
A knock at random when hot sounds like bad gas or low octane or carbon build up try some RXP for the carbon.
I think you're refering to pinging (pre-ignition or detonation) Engine knock and engine pinging have two distinctive tones.
Yes thats what I'm talking about,,
Old Sep 18, 2008 | 08:37 PM
So you think it's carbon build up?
Old Sep 18, 2008 | 09:05 PM
It shouldnt be that much carbon with those miles and the carbon cutter valves.
Take a small hammer and crawl under the truck and tap on the cats. It is rare, but the cats going bad can make it sound like lifter/rod knock.
Old Sep 19, 2008 | 07:49 AM
Landzu's Avatar
ORIGINAL: mellyagaunce
If the people before you used cheap gas yes,, you would have carbon on the top of the
pistons and that will raise the compression just enough to kick in the knock
sensors to stop the knock.
RXP is about $7 so its a good place to start if the noise is still there
after then keep looking.
I always start with the easy things to see if it helps, thats why I
also said to change the plugs.
Good Luck.
Old Sep 19, 2008 | 09:06 AM
So where do you buy this RXP?
Old Sep 19, 2008 | 09:16 AM
Landzu's Avatar
AutoZone, Pepboys its a 2oz bottle thats orange and will treat 25 gals
I have used it and found that it works, have seen it when doing emissions
on a Dyno with the NOX reduced.
wannabe
Jan 24, 2011 10:42 AM
tsuami1
Jul 4, 2010 05:25 PM
Baylink
Nov 7, 2009 08:49 AM
tunernewb92
Jun 23, 2009 04:44 PM
mellyagaunce
Oct 8, 2008 07:55 AM
