Engine Options
Engine Options
I searched, and came up with a few choices in engines. Most of those threads were full of I heard people doing this, or I once new a guy who did that. Only a couple actually had true facts from people who had done it.
There are options out there for a rebuilt 4.6, and some of those places have been around for along time. I know Atlantic British sells the 4.6, but I can't seem to find any reviews on their engine. Another option is Turner out of the UK, and this seems like the most logical choice. I also know about Roverland Parts, and Motorcars LTD. I'm leaning towards the Turner block, but wanted to hear from people with real experience to see what their thoughts are.
We're also open to a TD5 with manual transmission swap.
Thanks,
Mike
Thanks,
Mike
You can't go wrong with turner. They are top notch. There is also d&d manufacturing out of Michigan. They are very reputable and well respected. I'm sure others will chime in. In my opinion, Atlantic British is over priced. Have you checked local engine builders in your area also
I have not looked into having this done locally, and the couple shops in my area seem to have mixed reviews as well.
Received 1,167 Likes
on
Just got off the phone with Mark, at D&D Fabracation, and he will be doing the re-sleeving of my block, cylinder head work and maybe reassemble into long block form. Depends how busy I stay at work, just not finding the time to do this myself...but who knows...I may assemble. Was suppose to drop the block off today, but it will be next Saturday now. Heading to the garage at this very moment to get it ready for him.
Anyhow, Mark seems to know his stuff and has dealt with these engines quite often. I'm fortunate...his shop is only ten miles from my doorstep. So, shipping isn't an issue. Just google them and you'll get a bit of info off their website...or just call Mark.
810-798-2491
Now, I have no firsthand knowledge of their work, everything I've been told or read has been quite positive. However, after talking to Mark extensively...he assured me that I would be totally satisfied with the outcome. Wish I would have gotten over there today to see their operation, and could give you more info.
Good luck,
Brian.
810-798-2491
Good luck,
Brian.
810-798-2491
Good luck,
Brian.
810-798-2491
Good luck,
Brian.
The problem with a td5 build is the lack of folks able to work on it over here.
why not just put a 5.3Ls in it and run it on the Bosch engine management? Eric Brown at Trailhead will do a turnkey build for you and Lucky8 are also going to do installs.
+1 on D&D and Turner.
Most good engine options will have a wait.
Unless you're doing the swap yourself, 10 is a fairly good ballpark estimate to set aside for a full install, including engine.
My local Seattle indie charges 12 and up for a used 300TDI conversion into a d1 or Classic. It really depends on how many labour hours go into the LS conversions.
I'm being told the 4.8 LS with SAI will be around $10,300. Jumping up to the 5.3L aluminum might get the total up to $11k. This is something that we're considering, and haven't thrown it out just yet.
I can vouch for Turner Engineering as being the dog's whatsits, they have been in the engine business for many years and also specialise in Rover engines. They aren't 'el cheapo' but they guarantee their work.
As for a TD5 engine, brilliant engine and I can't fault it but I believe it wasn't sold in the US and is banned in many states. If you went down the TD5 route you'll need matching engine, turbo, ECU and gearbox and maybe check the diff ratios for compatibility. Just a few other things, you'll need a total TD5 exhaust system and maybe a TD5 engine wiring loom.
