Engine Overheating - Is it worth buying?
Old Apr 28, 2017 | 03:01 PM
Gulpy's Avatar
Exclamation Engine Overheating - Is it worth buying?
Hi all,
First post on this forum. I have never owned a land rover but I am finally in a position where I can purchase one. I have heard a discovery will teach you how to be a mechanic, but since I have never owned one before, I am hoping this community can provide advice.
I found a 2004 Land Rover Discovery II SE w/ 85k miles. The owner has been experiencing an overheating engine since January. In an attempt to fix this issue, he had the head gasket replaced with no luck. This solved the issue for a couple weeks but the engine started overheating again. He then tried bypassing the heater core but it did not fix the issue. The mechanic then did a pressure test and concluded it has a slipped liner. The owner also said the car loses coolant quickly and the engine does not produce any bizarre sounds.
Does this seem logical that it is a slipped liner? From my research it seems that slipped liners are rare. Therefore, would you take a $3,000 risk on purchasing the vehicle with the potential of needing to replace the engine?
Old Apr 28, 2017 | 10:13 PM
Friday Night Disco's Avatar
No, I would not. I would offer $1,500 cash depending on the condition. If the owner take the offer, do it and have the expectations it is a slipped liner and you will be paying to have work done and parts.
Old Apr 28, 2017 | 10:22 PM
disc oh no's Avatar
These engines are notorious for cracked blocks. I don't think I'd take the chance, personally.
Old Apr 28, 2017 | 10:46 PM
OverRover's Avatar
Originally Posted by gulpy
hi all,
first post on this forum. I have never owned a land rover but i am finally in a position where i can purchase one. I have heard a discovery will teach you how to be a mechanic, but since i have never owned one before, i am hoping this community can provide advice.
I found a 2004 land rover discovery ii se w/ 85k miles. The owner has been experiencing an overheating engine since january. In an attempt to fix this issue, he had the head gasket replaced with no luck. This solved the issue for a couple weeks but the engine started overheating again. He then tried bypassing the heater core but it did not fix the issue. The mechanic then did a pressure test and concluded it has a slipped liner. The owner also said the car loses coolant quickly and the engine does not produce any bizarre sounds.
omg............run!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 28, 2017 | 11:09 PM
Southern's Avatar
Originally Posted by Gulpy
Hi all,
They are not rare. My reading indicates they mostly all eventually fail.
My personal experience is, I have four Discos. Three (the D2's) had slipped liners / cracked blocks. The fourth (a D1) is still fine at 90,000 miles.
I wouldn't pay more than $1,000 for it depending on overall condition.
Old Apr 28, 2017 | 11:44 PM
jfall's Avatar
No no no.
Do not buy it.
Slipped liner is new engine time.
You can PIN a liner. But it is not easy.
You can replace liners. But it is not easy. Not for the backyard mechanic.
Buy a 2001 or earlier.
Or
if you are really smart.
buy an LR3.
Avoid the Discovery 2003 and 2004 at all costs.
They are pretty yes.
But the engines are more fragile then the 2001 and older
Old Apr 30, 2017 | 09:20 AM
Best4x4's Avatar
99-02 with a 4.0L are much better IMHO. Slap in an 04 CDL Linkage, 04 SLABS, and you've got yourself an 04 equivalent.
LR3 = a different bucket of worms... (very nice LR's but you must know what you're looking at or you'll be in a world of hurt if you don't!).
defend1ten
Feb 21, 2021 03:00 PM
meltdowndave
Apr 14, 2008 03:43 PM
MRDM1
Feb 26, 2007 10:49 AM
Tote
Mar 4, 2005 10:34 PM
