Engine Ping and Oil Press. Test Results - Feedback?
im sure if you PM mike he would return your mail.
but the first thing he will tell you is clean your engine, change your oil and filter and find your coolant leak or words to that effect.
you're noise is not an oil pressure problem, still doesn't mean the ring hasn't cracked.
you don't have a tick you have a wrap.
well; the top end does have a tick the there is a lower end wrap.
what year & who many miles?
what happens to the noise if you increase the rpm?
does it increase in sync / or does it drop off as rpms increase?
you can PM mike by clicking on any of his old links.
