vacumn leak and smoke test results
Old Sep 16, 2014 | 08:08 PM
dougn's Avatar
Default vacumn leak and smoke test results
I got a CEL and the code was lean on both banks so I did the smoke test. it appears the leak is at the front of the upper manifold gasket. this surprises me since I installed it about 40k miles ago (during a head gasket job) and torqued it properly..... also the bolts seem tight. my question is are leaks from this area common?
Old Sep 16, 2014 | 08:53 PM
Jared9220's Avatar
Are you sure it's not coming from one of the fuel injectors o-rings? You might need to remove the drive belt, pull the 4 bolts for the A/C and move it aside to see better.
To answer your original question, No, it's not common to have a leak there after only 40k miles if everything was installed correctly.
Old Sep 16, 2014 | 08:56 PM
dougn's Avatar
yeah good idea.....the code I think was 1174 which was lean on both banks
Old Sep 16, 2014 | 09:17 PM
Jared9220's Avatar
1174 is lean on bank 2 (RH)
1171 is lean on bank 1 (LH)
Trouble codes from RAVE.pdf
I have had both 1171 and 1174 before and both times it was a vac leak so I think you are on the right track. I made a "Smoke test with a Cigar" thread because of those codes. https://landroverforums.com/forum/di...s-cigar-54235/
One time it was the intake tube not on tight and the second time was the lower o-ring of an injector. The intake tube was an easy fix the injectors took a bit more work but isn't super hard.
Old Sep 16, 2014 | 10:14 PM
dougn's Avatar
I did take somewhat less than a quarter turn on the manifold bolts and it's idling at lower rpm. temporary.....
we'll see what happens tomorrow
Old Sep 16, 2014 | 10:15 PM
ImQuattro's Avatar
I had the same codes pop up a while back. While I still have yet to address them, I did smoke the intake with our Bluepoint smoke machine and found a badly leaking lower injector seal behind the A/C compressor. Strange because the seals are new and only have around 6k miles on them since the rebuild.
I'll tear into it when I get time.
lrsmith62
Sep 29, 2014 07:26 PM
TripleThreat
Feb 14, 2014 09:21 PM
btbaus
Jan 20, 2010 04:38 PM
Bryan H
Apr 6, 2009 05:28 PM
eandrews2
Mar 18, 2009 08:18 AM
