engine replacement
Old Feb 14, 2012 | 08:13 AM
hhalimi's Avatar
Originally Posted by ljdiscovery
The transfer case reseal can be a bear and expensive. You might try some White Shepherd by Univeral Products. You should be able to find it at your local Advance Auto Parts Store. It is about $20 a bottle. One bottle should take care of your transfer case issues. you should get a small had pump to help get it into the transfer case, the filler plug is a little tought to reach. I have used the white shepherd on several of my rovers with good success on the transfer cases. They claim to have a money back guaranty, ......Good luck. Phil
current LR Disco II 2000
A third of a bottle is suppose to be there, at least I gave it to the mechanik to put it in, when he was doing the oil change. I am planing on pouring some into my engine, since I have discovered severeal areas of leaking and will put some more in the transfer case.
Thanks for the advise.
bennyb43
Nov 28, 2015 04:01 PM
tcbinaflash
Jan 8, 2008 04:23 PM
redhat988
Nov 6, 2007 10:33 AM
desmond
Defender
Jan 19, 2007 10:22 PM
RedRoverRedRover
Jun 20, 2006 01:04 AM
