Engine stumbles at stop
My 04 D2 runs pretty well except that it has started to run rough when I have the a/c on and come to a stop light in Drive. Seems to run fine otherwise and not throwing any codes. My mechanic just checked the plugs/wires/coil pack and all was well.
I'm going to spray the MAF with MAF cleaner this evening. I was wondering if there was anything else that I should explore as a cause/solution.
Thank you!
Thank you!
handsome rob
04-17-2010 03:47 PM
