Engine stumbles at stop
Old May 13, 2022 | 08:57 AM
NVDiscovery's Avatar
Default Engine stumbles at stop
My 04 D2 runs pretty well except that it has started to run rough when I have the a/c on and come to a stop light in Drive. Seems to run fine otherwise and not throwing any codes. My mechanic just checked the plugs/wires/coil pack and all was well.
I'm going to spray the MAF with MAF cleaner this evening. I was wondering if there was anything else that I should explore as a cause/solution.
Thank you!
Old May 13, 2022 | 09:46 AM
nashvegas's Avatar
Hmmm... interesting. **Only** when AC Is on then?
Its *not* a crank position sensor, that is for sure.
I would have started w/ plugs/wires/coil packs on this as first step.
When you say run rough ... is it idling low, missing on cylinders... a bit more description?
Old May 13, 2022 | 08:51 PM
Cleaned the MAF and maybe its better. We'll see this weekend.
Is not throwing a misfire code and drives fine. It just stumbles intermittently when I have my foot on the brake at a full stop.
Old May 14, 2022 | 01:57 AM
Richard Gallant's Avatar
vacuum leak ?
Old May 14, 2022 | 06:19 AM
That's what I'm thinking. Not sure how chase that so I'm open to any ideas.
Old May 14, 2022 | 07:20 AM
Alex_M's Avatar
If it's only when your foot is on the brake them try plugging off your brake booster hose and see if it still does it. Could be a tear or something in your brake booster. Careful, you won't have power brakes with it disconnected.
Old May 14, 2022 | 07:35 PM
Its actually running better this afternoon after cleaning the MAF yesterday. Headed out for a long drive on Sunday so we'll see how it performs. I'll provide an update. Thanks for everyone's help.
Old May 16, 2022 | 09:51 AM
So far, so good with cleaning the MAF. No more stumbles at stop lights and throttle response much better. Might even have better fuel economy...
ihscouts
Oct 20, 2014 03:58 PM
ChefGabe
Jan 26, 2013 09:35 PM
chermecz
Sep 17, 2012 08:11 PM
handsome rob
Apr 17, 2010 03:47 PM
mestupstud
Dec 12, 2007 09:57 AM
