Engine swap parts list
#21
Yeah. I never said the factory changed their manufacturing specs. Fact is, they didn't but the quality of the block castings and tooling/machining deteriorated over time so the earlier 4.0 Litre P38 engines were generally accepted as better. The factory had a way to test the quality of block castings using ultrasound (I think) and marked the castings with daubs of paint inside the lifter galleys to indicate level of quality.
Red paint was applied to the best castings which were generally reserved for their most expensive vehicle which was the Range Rover. Blue paint was applied to blocks that were deemed good quality; these could be fitted to a Range if the factory ran out of Red blocks. Blues were most often fitted to Discos. In both 4.0 and 4.6 configs I have seen Reds and Blues. I understand there was also a Yellow graded block but have never seen one.
The deterioration in the tooling/machining over time is evident in the poor fitment of 4.6 front covers which causes the oil pump problems that anyone here can tell you about, among the other problems these engines have.
thst is why 4.0 Disco's and 4.0/4.6 range rovers have less problems.
#22
#23
also they abandoned the grading process with the 03/04 discos because that was the only vehicle that was Getting those motors and it was the end of the production cycle. It has been said that they even used rejected blocks that were on the shelf.
#24
I haven't read that in the literature you posted. Unless I just haven't read far enough, the case appears to be that as long as the engine is a genuine Land Rover unit, none of the 4.6 engines used anything less than a yellow block, and then only if they ran out of red. This was until the end of the run in 2004.
#25
Interesting. That's an assertion that I would like to see confirmed in some way, I.e. taking several known original Rover blocks from 2003-2004 U.S. discos and checking the valleys for color marks. I would think that, if they were indeed just throwing whatever came out of the foundry into their vehicles, they wouldn't have bothered with the testing and marking as is reported in that literature.
I would be more inclined to believe that there a mostly yellow coded 4.6's floating around rather than red, but to have every 03-04 engine get a blue or worse rating seems unlikely, even for a company in dire straits like Rover was.
#26
Is there a comprehensive writeup on the rover "knock"? I ask because i did extensive research months ago before replacing my head gaskets and came across this article JE Robison Service - Bosch Car Service Specialists ? the blog: The last word on Land Rover liner failures - I hope! , among others, that explained the block failures and causes of the knock.
According to this, and other sources, it would seem that the 4.6 is incapable of "slipping" liners. The block can crack and result in an overheat/coolant loss situation, but the liners cant physically move.
but then i also seem to remember a writeup that insinuated that LR failed to seat all of their liners properly, resulting in the slip phenomena despite a block design that would otherwise prevent this.
#27
There's a lot of information on this but suffice to say the Rover friction fit liners can definitely slip. What happens (quickly) is (1) hairline cracks in the water jacket can form which causes coolant to leak behind the liners. This 'lubricates' the liners from behind, and with the pistons moving up and down causes the liners to unseat and slip causing ticking. Sometimes even without a coolant leak behind the liner they come loose due to overheating, in many cases due to oil pump failures which the later 4.6 engines have become famous for. As an aside I also believe the rearmost cam bearing can get loud and make a sort-of ticking noise. The oiling system of the valvetrain is also dated and inadequate in my view, so rocker, lifter and pushrod noises are also common and can be called 'ticks.'
#28
Yes I understand that the blocks Crack, and this is generally the cause of slipped liners, but the info on this is very sketchy. And by that, I mean the the data points are all over the place.
For instance, that forum post and subsequent video "proving" that 4.6 liners slip at normal operating Temps. The guy probably didn't confirm that the engine was a genuine Rover unit, only that it "appeared" to have ever been apart. It could have very well been an early crate motor that replaced an oil pump failure unit.
#30
The blocks used for replacement were Coscast blocks. A company that was hired to fix their block issues for the warranty replacements.
When you think about it, during their casting process they ended up with 3 grades of blocks. Red, Yellow, and Blue. Red was for 4.6 motors that went into RR. Blue for 4.0 and yellow was used for either when the prescribed one was not available.
Keep in mind, the grading was based on the random output of the casting process, they could not necessarily control the process, it gave them what they got.
In 2002 14,095 D2s with 4.0 motors came into the US. Same year 3,927 Range Rover P38s were imported. Some SE and Some HSE, but I do not have the breakdown. For arguments sake, lets say all were HSE, hence all were 4.6.
We can then make the deduction that 78% of the blocks used were Lower quality. Granted, I'm taking some liberties with my theory and numbers.
Do you think once 03/04 production came when they no longer were putting these motors in Range rovers, meaning they were only making 4.6 motors not 4.0(which was the lesser of the production numbers) that they discarded 78% of the blocks and only used the red ones for the full production numbers?
To me it makes perfect sense. Also, I have bought and sold many Discos and can say hands down that I have seen more failed 03/04 disco motors than anything else. Thats why it is advised to buy a P38 4.6 for rebuild.
But hey, I am just a monkey with a wrench...
