Engine Temp question
Old Nov 3, 2014 | 03:59 PM
abran's Avatar
AB doesn't sell the original grey color TD5 one, unless they started.
If you paid less than 75-80, its not the right one.
Originally Posted by clint70
Thanks dusty1, that is what the AB salesman said too. The 'soft spring' was original equip for the diesel, so it must be the right one
Old Nov 3, 2014 | 06:03 PM
OffroadFrance's Avatar
Originally Posted by dusty1
the 180 usually references the td5, as it is original equipment for the diesel.
Spot on Dusty. Td5 being diesel runs hotter under load and has a much smaller engine.
Or even better still get a TD5 lump instead ............. less aggro all-round
Old Nov 4, 2014 | 07:25 AM
clint70's Avatar
OK... thanks Abran. Just a quick question then, where do I get the 180 t-stat? Will AB have it or do I need to get it elsewhere? I am going to have to return the 'soft spring' one I suppose. Thanks for the heads up
Old Nov 4, 2014 | 07:35 AM
dusty1's Avatar
rovers north for sure. maybe lucky 8...not sure
Old Nov 4, 2014 | 07:46 AM
drowssap's Avatar
AB does not have the genuine LR TD-5 thermostats
Old Nov 4, 2014 | 08:37 AM
clint70's Avatar
Found it at Rover North... 80.00 dollars - SPENT So I will send the soft spring back. Thanks again for the help, I will follow up to let you all know if this makes a difference. Till then - Cheers!
Old Nov 4, 2014 | 10:51 AM
Andy2Rover's Avatar
Isn't this the 180 degree thermostat? It has the correct part #PEL500110. This is from AB website:
Land Rover Discovery II Replacement Thermostat
Old Nov 4, 2014 | 10:53 AM
drowssap's Avatar
its a copy, AB genuine parts end in a G "I believe"
Old Nov 4, 2014 | 01:49 PM
poncePR's Avatar
Inline thermostat=Mucho happy
Old Nov 8, 2014 | 11:44 PM
clint70's Avatar
So I received the180 t-stat and installed it today... did some running around town to check the temp on Ultra Gauge, here is where I am now:
idle at a lights: (old) 200 - 205 F (new) 189 - 194 F
Highway: (old) 196 F (new) 187 F
climbing the mountains in CS (30 mph): (old) 200 - 209 F (new) 189 - 196 F
I am hoping this will help extend the engine life a little more, as I know I am living on barrowed time... HG probably needs to be done shortly. As it has not been done to my knowledge yet and I currently have 152,000 mi. Very happy so far... thanks for the help.
Cheers!!
