Engine Temp question
#22
I'm in the Springs as well. Your temps are a bit higher than my D2 with a new Hayden HD Fan clutch and genuine TD5 180 T-stat. I'm normaly 94 max at idle, and 201 max climbing the passes around the front range or slow going offroad. 95% of the time around town I'm in the 188-194 range.
Hope that helps!
#23
#24
#25
Hot climates for sure. I also run one in Wisconsin where it can hit -30F. The engine still heats up at the same rate to operating temperature, the thermostat just helps with not hitting the higher temp ranges and allows the coolant to flow through the entire system faster than a stock thermostat would, thus keeping everything a bit cooler.
clint70 (11-13-2014)
twilightcall
03-04-2018 06:55 PM
rrbc
11-13-2009 04:59 PM
