Engine temp spike and radiator temps
Old Sep 30, 2013 | 12:58 PM
grandkodiak's Avatar
Default Engine temp spike and radiator temps
I rarely drive for very long in my Disco, its mostly a rainy day/winter car, commuting to work is a 20 minute a day round trip, and even less for trips to the store etc... but I was on the highway this weekend for about 3 hours duration going on a trip (195ish F all day long on the highway). Normally my idle/slow traffic temps are about 210-215 max, high speed fans kick in and it never goes above that.... been that way for over 3 years so...
Anywho, on my way home I noticed after getting off the highway my temps creaped upto 230 F and stayed there at a traffic light, dropping back only after I started moving again (wasnt a particularly long light either). When I got home, I took my IR thermo (it was at 215 F when I turned it off at home which is the normal high temp idling etc) and got some strange readings. The thermo only registered 85ish +/- 2 degrees F at the top of the radiator, and about 6-8 inches below that (the farthest down I could angle the thermo through the front grill) at 75ish F. I was tired and only had a few momments to tinker around, but i intend to look at it again after work, let it idle in the driveway and IR temp map the radiator better, and maybe a few other spots. Driving to work today the temps looks normal, never exceeding the 210-215 range.
(ps. i have a 180 thermo and plan on getting a new radiator anyway, just rough with money now)
Old Sep 30, 2013 | 06:01 PM
Try to repeat your test warmed up, but on the back side of the radiator. Sounds like radiator is clogged on the bottom or higher. $200 Nissens at Rock Auto. Is the 180 stat a Land Rover one? And the fan clutch couild be wimpy, when warmed up give it a spin and release, should stop is less than one revolution.
dparham
Apr 17, 2015 02:54 PM
dparham
Apr 14, 2015 08:44 AM
Travelor
Feb 25, 2015 10:35 PM
arod829
Nov 4, 2012 11:12 AM
tigertrakstar1
Jun 1, 2010 10:07 PM
